TPMS for W204
dazzle
Hi bros
Gotten a used W204 recently.
Am looking for a TPMS set for my ride.  Anyone has installed TPMS on their ride ? and does it integrate with HU or separate display ?
Thanks and appreciate any advice
Your ride should have come with Tyre Pressure Loss Warning system.
Unlike TPMS where you have readouts of individual tyre pressure + Temperature.
Tyre Pressure Loss Warning System will give a warning message if your tyre pressure in one wheel is much lower than the rest of the wheels.
Thanks bro kepiting1sg for your reply.
This tyre pressure loss warning system thingy, i can't find it in the menu.  Is this something on the settings ?  or is "invisible" but there ?
Can I set the pressure at which a warning be triggered ?
APologies for the noob questions but appreciate advice.
If you scroll your menu, there will be a "No message" display
You can set your tyre pressure!
The system will display a warning "Low Tyre Pressure" msg when one of your wheels is losing too much pressure
Hi
found the menu, where there are three options
1. No Message
2. Tyre Pressure
3. ASSYST
I clicked on "Tyre Pressure" and it say "Run flat indicator active".  Is this the one ?  I can't set any tire pressure here .  I can only restart "Run flat indicator".
Am i on the right page ?
Thanks
Hi
1. No Message
2. Tyre Pressure
3. ASSYST
Thanks
When there is a lost of tyre pressure in one wheels - there will be a message
Sorry - Typed too fast - Shout be restart not set.i.e after you resolved your wheel pressure problem, pumped up the required air pressure, then restart
But if its losing pressure at the same rate the system will not alert you even if its going flat
thanks bro thaiedwin and bro odessus for your response.
I understand now that the alert for abnormal loss of tire pressure is not shown anywhere in the menu but is active .
(1) Is there a system to monitor the tire pressure of the tires ?  or i need to install a separate tpms ?
(2)  What tpms would bros here recommend for our ride ?
(3)  Then what is this "run flat indicator" that is on the menu ?  Does it mean it supports run flat tires ?
Pardon me for the many noob questions.  my 1st merc........
Thanks in advance
You'll need to install separate TPMS for your purpose.
Run flat indicator just informs you when one of your tyre pressures are very low compared with the rest therefore suggesting a flat tyre.
ah ok.  I understand.  So the Run flat indicator is the tire pressure loss alert thingy.  THanks
Any bros here installed any tpms on your rides and any brand to recommend for our rides ?  I saw the orange one.  anything else ?  Any that integrate to the HU ?
THanks again
