Air Circulation Mode
Hi guys,
Everytime I start the B klass, I will need to press the button for air circulation to turn on the air circulation mode - cabin air will be circulated. However, it will be switched off automatically for no reason and outside air (e.g. exhaust from the front car will enter the cabin). C & C explained to me that this is normal for all Mercs. Not sure if this is also true for your car. Can anyone advise on this?
Thanks.
This topic is not new and has been discussed many times, try using the search function. Anyway, this is mercedes safety feautures, to allow outside air enter into yr car to circulate. This is in the event of carbon gas leak eg a couple stays inside the car for hours dont know doing what!! or driving long hours in highway if no fresh air circulating likely anyone inside the car will up lorry!!
thanks bro.
Will search
It switches off the recirculating mode after 30 mins of urban driving. (Believe should be less if on expressway when ave speed is higher). Just reset the recirculating mode when it switches off. :)
Thanks bro. I noticed for mine about 10 mins of driving it switches off. Not sure the reason thou.
U can ask the cnc service guy to set the timing from 10 mins to 30 mins.
Maybe someone in the car "farted", the car oxygen sensor detect shortage of fresh air thus switch over to circulating model hahaahaaa.....
if i understand correctly, the o2 sensor is not located inside the cabin. thanks.
o2 sensor is located in the engine bay
now i think back, i finally realised why the air con blow to the legs first....make sense...
why?
like blackmercs said, is a safety features, usually when car start up, the air that blow up may carry some virus or gems that reside in the AHU, and if you put your aircon at auto mode, it usually blow at high speed directly to your face...so you will suck in all the virus & gems, i read somewhere that advise us to wind down window when we first start up the car, to allow fresh air circulate inside the car before move off...
with the air that blow onto the leg first, it actually reduce the air directly onto driver & passengers onboard...
tio bo?
