Can this work as Logic 7 Setup??
bobven
Can Audio Sifu's advise if this schematic can work on a C class as Logic 7 using JBL MS 8?
BobVEN
Proud Owner of Merc C200 CGI
Pioneer HU P99RS for Sale ! Please click the link below..
http://www.sgmerc.com/topic/14541-pioneer-dex-p99rs-component-cd-receiver-for-sale/
Launch Creader VIII+ OBD2 Scanner for Sale ! Please click the link below
http://www.sgmerc.com/topic/14558-obd2-scanner-launch-creader-8-for-sale/
  • Replies 15
Not an expert but my view is the the center channel need an amp.. if not the tuning of MS-8 may tune down the level for other channels. instead of a 4 channel amp get a 5 channel amp.. Front staging is important.
I do not understand why you need a bridging for the rear since you already running a coaxial for the rear; the rear should be more for fill and rear effect.
Too many speakers may not be good in a small enclosed space like a C class.
Thanks bro
Even the Harmon Kardon setup has so many speakers.. I tried to follow the same..
BobVEN
IMHO.. The MS-8 cannot tune for your bridge..
oh.. ok.. I got it
So.. it need to be 8 individual channels...
BobVEN
You can ask kepiting1sg on this. He's our go to guy for anything I.C.E related, should be able to advice you on this.
Alternatively run the front as a passive setup, then MS8 8 channel can run front, side, rear and sub setup.
You mean like this ?
X over the Tweeters to Front door speakers. This mean
Ch. 1 = FL
Ch.2 = FR
Ch.3 = SL
Ch.4 = SR
Ch.5 = RL
Ch.6 = RR
Ch.7 = Center
Ch.8 = Sub
BobVEN
Yup.. using the passive crossover network that come with the component speakers
Thanks.. here is the new diagram... :)
PS: I got 2 x 4Ch Amps removed from my previous ride.... gonna use by skipping 1 ch ;)
BobVEN
For me i will get a more powerful amp for the front and center esp since the front include a passive crossover.
I will use a lower power amp for the side and rear..
You using Active sub?
How many watts u plan to run per channel?
I have a 800W and a 650 W
Plan to use 800 for doors and 650 for rest
Sub is Pioneer (inside the spare wheel one)
BobVEN
Decent power.
Pioneer sub cannot go low.. a customised sub enclosure is better if u can give up boot space
My installer said.. for SQ setup it is good...
I cant let go the boot space... my wife will chase me with broom stick like this below :)
400_F_11173170_UDrwVL5arhQHJsXt0HXvoug9Q
BobVEN
imho
For HK Logic 7 is more for a HT & that why it includes a pair of rear surround speakers.
For pure SQ like home audio you just have a pair of 2 way or 3 way speakers.
Likewise strictly for SQ,
2 or 3 way active front with a 12" sub in a sealed box if you are a bass head cos 10" sub won't go to the lower Hz.
Get a good processor with time alignment & a tuner with a good pair of ears :)
In the past not many tuners can tune a 3 way active front satisfactory.
Nowadays many tuners go that extra mile to tune a good 3 way active front set up.
IMHO there's no such thing as over-powered but instead lots of headroom.
A 4 channel amp to drive the front mid & tweets, a 2 channel higher power than the front channel to drive your mid bass, a monoblock to drive your 12" sealed sub.
Look for a sub that need <1 cu ft of volume or throw away your spare tyre to have space for your sub there. Happy ICEing :)
