Unable to drive
As usual, drive to work.
After my work, I started my car and engine as usual. To my surprise, when I shifted the gear to "D" and press on the accelerator, my C180 could not move. I put more pressure on the pedal but no response. Check leg brake have released and off all battery operated gazette. The engine is still running but could not drive out of the car park lot.
I repeated it by switching off and start the car again and the same results. Decided to call C&C and was advised them to do the motion again. My car was still under warranty and they would be dispatch the technician to meet me.
After about 3 mins later, I tried to start again and everything went as normal. I can drive the car and cancel the dispatch from C&C. Was advised to driver to C&C to have a computerised check on the car.
Well, nothing found and checking. Everything working perfectly.
Any driver encounter this problem before?
