Can CLS Rims fit W212 Sedan?
Need help to check if Stock Rims and Tyres from 2013 CLS can go into 2011 E Class Sedan (w212).
Appreciate all advice. Thank you.
Front alloy wheels         Back alloy wheels         Tyres (front)          Tyres (back)
E Class Sedan    18x8.5" ET48               18x9.0" ET54               245 / 40 / 18         265 / 35 / 18
CLS                  18x8.5" ET34.5            18x9.5" ET48              255 / 40 / 18          285 / 35 / 18
  • Replies 4
The front may or may not rub against or jug out of the fender - fitting test will know!
The rear wheels likely no problem.
If you use the rims, make sure you have the right size of tyres for your E Class.
Also take note by taking the CLS rims, you have alter the track of your E Class.
How much it will affect your handling - I dunno!
Thanks for your swift reply, kepiting1sg...
I was told by the guy who's selling the CLS rims that I could use the stock staggered tyres set-up for E Class Sedan on the CLS rims - use 245 x  40 x 18 and 265 x 35 x 18
Will this work?
Will this work?
That should be the right tyre sizes for E Sedan W212 on 18" rims.
Best before you buy, go for fitting test first and ensure that it doesn't rub or jug out of the fenders front & rear.
