Can VW rims fit MB W204?
  • Replies 4
Juz curious if the rims are PCD 5x112 and ET45. Not sure what is the centre bore diameter tho.
PCD will fit, offset dependent on model.
Center bore for Audi's usually smaller, can be solved with appropriate adapter size. Lug bolt diameter may differ.
Centrebore for most of the VW is 57.1mm same as "older Audi models".
The newer Audi models has the same Centre bore diameter as the MB at 66.6mm
