Hi all
Recently, my CLA 200 ride, check engine light came on in the morning when I started the car. I sent in to a workshop for diagnosis and they said was timing gear issue. They told me to go to C&C and check to confirm. That same day, in the afternoon, the check engine light went away.
Anyhow, the next day, I still send in my car to C&C. Even though the check engine light was gone, I thought the fault code will still be in the memory. C&C told me to replace the turbo engine. They couldn't find any issue with the camshaft or timing gear.
My mileage is about 61,000km. Need some advice when the turbo engine and timing gear should be changed. Any symptoms to take note.
Thank you.
Share this post
Link to post
You mean the turbocharger unit and not the engine?
Send to a reliable workshop for a diagnostic check for 2nd opinion.
My previous W212 turbo unit was replaced around 180,000 km.
Share this post
Link to post
Yah, the turbocharger unit. :D
What are the reliable workshops around? Thanks!
Share this post
Link to post
1. Autospritze - 1 Kim Chuan Terrace
2. TLS Auto - Block 1010 #01-113 Bukit Merah Lane 3
2. MBM Wheelpower - 160 Sin Ming Drive #06-02 Sin Ming AutoCity
Share this post
Link to post
Thank you so much!
Share this post
Link to post
Hi kepiting1sg, thanks for the recommendation. I went to TLS Auto and they fixed the issue. Am impressed with their quality of work.
Share this post
Link to post
Happy for you they fixed your issues!
When Vincar own workshop is overloaded, they spillover to TLS
Share this post
Link to post
