Finally collected my glc coupe!
mysticryan
5 minutes ago, VRAtenza said:
That's 19" staggered for the coupes right?
The rear looks like it sticks out more than if it had been non-staggered.
Yup. Staggered set up. Width of my rear TYRES are wider. Both my front n tear rims specs are diff.
Thanks for that! Do you by chance have the specs for your rear tyres and rims (offset+rim width)?
Also do u have a measurement of the outer edge of top of your tyres to your rear fender edge?
I am trying to use your car/wheel setup as a reference for size of spacer I need to push out my non-staggered 19" AMG rims.
Thanks!
Thanks!
My tyres info. That's all I hv.
Tyre - Front 235/55 R19, Rear 255/50 R19
57 minutes ago, Michaeltoh said:
Thanks for that! I further searched. Seem like front is the exact same ones as the non-staggered and for the rear the rim depth is 9 inches and offset is +20 instead of +38.
Calculated using online the rims size calculator, in other to achieve around the same stance as the coupe's staggered setup, the rear of the non-staggered 19" need to push out by 31mm.
