Water hose leaking from engine inner (near to exhaust)
prodrivegsr
Driving an E200 model W211. Found coolant missing due to a coolant hose that is near to the inner engine (near to the extractor - above gearbox).
Anyone has any experience and able to advice where to send for repair and estimated cost ?
Bro, don't understand what you mean by "missing"?
The hose is held down by spring-clips and both end...even if it bursted, it would be missing...
2006 W211 MERCEDES E200NGT
Ha ha... Leaking due to a hose locate at the inner engine area near to the extractor... Any recommended workshop ?
The usual suspects i.e MBM, AutoSpritze, Optima, Chip Soon, etc
  • 3 months later...
  • 9 months later...
Bro, have you rectified the missing coolant problems?
I also had coolant warning this morning...got to top up almost 1 litre of water into the reservoir tank.
I noticed there are some white-power water stain mark on the gear box when peeping into the inner engine area.
Which workshop you visited for this problem and can advise on the damage$  ?
