Intake Camshaft Adjuster & Key Lock Issue
Pumper
Hi all,
I am driving a 2010 pre-FL W204. Recently my car has difficulty cranking and the Engine Check Light came up. I sent into C&C and it was diagnosed with timing gear intake camshaft adjuster issue. They also detected the steering key lock or 'green key' issue as well.
The cost of repairing with C&C is erm...kinda high... =(
I am enquiring if these are easy fix in which outside workshops are able to do? And any recommended ones?
Thanks in advance for advice!
  • Replies 6
Green key issue is better to let cnc to do it as the cost is cheaper. Go to other ws to check out the pricing.
Hi all,
Key issue C&C charge S$1500, i think is the most cheapest in the market so far, unless you are own a parallel import car.
I███████████████████].
  • 1 year later...
