Check CEL - Code PO171, System too lean (Bank 1)
Guest io5885
Guest io5885
Kena CEL last nite. Check using a OBDII reader, got the code PO171 system too lean (bank 1)
went in Msia last weekend. Pumped 48L of V-Power Racing at Shell just b4 Tuas Checkpoint.
4 days later, kena CEL.
2009 W204 C200K
Lost..
Anyone can advise more? :huh:
Surf thru Benz World, some say due to
1. vaccum hose leak
2. MAS, airflow sensor dirty or spoilt
3. fuel
4. Gasket spoilt
5. Fuel filter choked
  • Replies 3
Guest hkhamateur
Bro ivan, indeed a gd findg. :)
Unfortunate to learn abt yr system pb bt bringg it to C&C shld solve it. Last visit to Starblack, i make request to hve my MAF clean via brake spray bt was nt adv coz its v extremely sensitive as it may damage. :pinch:
Its yr air filter stock or any other oem ie: harricane, K&N, Simonta etc.... :blush::blink:
Otherwise it cld hve been e daily traffic greese/ dirt tat may contaminate e sensor! :ohmy:
Guest io5885
Yo Bro Hong,
The usual age of the car when the sensors get dirty or vacuum hose leaks, is around 5-6 yrs from my reading on web.
I managed to reset the code with a OBD2 reader and constant monitoring for now.
Car is good with no noticeable differences in performance.
I'm on Hurricane S/S air filter. Took it out n inspect yesterday. Ok. last wash 2 mths back.
if CEL pops up again, will send it in to See&See, to let them see & see.
My suspect is the V-Power Racing from the across the causeway last sunday.
I top it up with Esso98 in Singapore.
Half tank mark but i poured in 42L. A bit off my usual calculation.
Worried dat "seasoning" might be added to the V-Power dats y it leads to system too lean.
Btw, y the clean of MAF with ur last visit to SB?
really hope mine is a one-time off false reading.. :lol:
