Newbie Ques
Guest EljayNg
Guest EljayNg
Hi All,
Can I know if i can transfer my current ICE setup from my Civic to my new W204 that I bought? will it work?
as info, i am using a soundstream amp and crossover with helix speakers.
thank you :)
  • Replies 8
Hi All,
thank you :)
Welcome!! Sure it will works but u are unable to use the steering for control. Apart from this, loss of bluetooth function & ipod etc. As for speaker fitment seek yr audio installer for advice. Hope yr ride does not comes with Command unit :).
comes with it. how ah? it will render it useless it i add my amp? if this is the case' date=' i will not touch it! thanks![/quote']
Comes with command arh. Sell it away & install yr old ICE set, if u must!!! Is yr call, most importantly seek yr audio installer for advise before swapping. Good luck!!
sorry seller told me its audio20!
apologies i thought command unit was referring to the round knob! :(
Go to Wee Heng/AutoSpritze or your regular ICE workshop for more alternatives.
115 Eunos Ave 3
Look for Ah Boon.
Guest IEM3333
Been a long time now... Wish everyone here is still good...
TS, Itz possible to use yr steering control and all the goodies that come with the car...
Im running a Scanspeak 3-way up in front, ODR to run my disc and a 9' Sub in the rear but intending to shift it up front to the passenger floor board... Kazaar Tube amps and a mono for my sub...
No prob with the Ipod and bluetooth...
Guest EljayNg
thanks buddy which shop did you go to?
thanks also to the rest who responded in my thread!
  • 3 months later...
