LED DRL
Guest Curtis84
  • Replies 13
Guest Curtis84
Instead of the LED strip, you get 2 fog light bulb lor. Those are non-led i suppose. I get 2 white lights in the day, but looks pretty dated that is why i wanted to change it.
C&C dont offer LED DRL unless you are getting the SLK 350.
Guest markcwq
Is there anywhere that i can change the non LED DRL (those offered by C&C currently) to the LED ones for SLK 200?
how to get to them?
You can ring Steve from Sonic Racing at 86689119 to enquire.
Guest clarkewan
is it using h11?
maybe can add a canceller and then replace the bulbs to LED type?
maybe cheaper alternative?
bulbs is selling at shops at S$75 and cancellers are at S$12 a pcs which we need 2 pcs....
:D
so total will cost say S$99
Guest markcwq
Whatever modifications you do to your car, the warranty will definitely be void for that item. As an added clause, if C&C traces the problem of any fault back to your modifications, it will also not be covered under warranty.
As I've learnt from the seniors here, mod don't scared, scared don't mod.
Guest Curtis84
So if i mod LED, C&C will not tell me Aircon/radio spoil cannot claim right? Anyway, headlights are always not under warranty rght?
Guest markcwq
Cars now are all electronically controlled, you never know what you do might affect something which you think is non related. Any third party technician will always tell you that to cover themselves in case anything goes wrong. Every part of your car including the headlight unit is covered under warranty. Only thing that's not covered is the usual wear and tear and expandable items such as the bulbs.
The guy who installed my HID told me if I'm unlucky and the bulb explodes inside my headlight unit causing it to be damaged, it won't be covered under warranty.
Guest Soulz
I have called c&c and check with them previously, warranty will only void for that item. But say if while changing your led, the mechanic damages your other wirings, whatever that are damaged will not be under warranty anymore. From experience they will not purposely push the blame to your mods. Hope this helps. :)
