WTS : E250 CGI Piggy Back ECU
Guest busdriver
Guest busdriver
I have a set of VATH E250 CGI Piggy back ECU complete with Harness. It has 7 settings for you to set your preferred mode. Used for a month and took it out as I felt I can't get the desired results cos I somehow end up comparing with my other cars like the Evo X. It is plug and play and doesn't need any cutting or splicing the stock wires. Asking S$1,500. SMS me at 97990007.
  • Replies 9
Guest Leftfield
Hi, what are the increased hp and torque numbers from the piggyback?
Guest busdriver
Price Reduced to $1200. It has 7 maps to select from. High boost to quick spool low boost. Plug and play. Just remove before sending car in. Will not void warranty. It's got a bypass socket for you to revert to stock quickly without removing the ECU as well. Comes complete with plug and play harness that reads boost, cam position, throttle position as well. Think this piggy back has the most reading it handles compared to the rest in the market.
