help with installing sprint booster
hey guys. planning on getting a sprint booster, but kinda lazy to go down to a workshop to get it fixed. any bros/sis down here knows how to install the SB?
been searching for a guide to do it online, but only found one for the mini and chrsyler crossfire..
if you know how to dismantle the pedal and plug in the SB, please help me out..
thanks in advance.. =)
Protoss ]
Better dont mess with the installation coz if done wrongly, got to call tow truck liao.... 8)
got some advice from david that its kinda simple to fix for the c class... so yea, will see how hand itchy i get once i touch the SB... if too much i go testing... den better hope dun need to call tow truck.. wrote:
Anyone know whether the sprint booster is compatible with the W124 8 Valve?
if the w124 is drive-by-wire i think can... other than that im not too sure... can call up MBM to ask...
ok heres the instructions on how to install a sprint booster (for w203, not sure for other models)
1) pop the cap cover behind accelerator
2) unscrew bolt
3) remove accelerator(1 whole pcs)
4) unplug connector from car
5) plug connector to SB, sb connector to car, & reverse assembly
6) that's it
probly take u abt 15mins in all
credits to JenVid for the instructions.
Guest ultor
SB does not add torque or hp but simply improves your car responsiveness when you step on the accelerator. It amplifies your acceleration too so be careful initially. Overall, it helps with overtaking and changing lane.
