Auto Headlamps
Guest silverarrow
Guest silverarrow
Hi Bros, got a question on the Auto headlamps. I usually start my daily journey at about 6.45am when the sky is still not fully lit. The headlamps are switched on automatically as expected. However, I noticed often enough that the headlamps still remained switched on after 8am when the sky is already brightly lit. What time does your headlamps switch off in the morning?
Guest lightning
quite common bro...depending on the weather... as for me usually off by 7.30 ~ 7.45am...the light sensor is located on the dashboard and I believe the huper optik solar film might have blocked off some of the UV ray...so less sensitive lor :tsk:
needs really strong sunlight to turn off by itself. as mentioned by bro lightning the window tinting play a part too
