Should I buy the Philips HID conversion kit?
Guest grey3443
Guest grey3443
jtang wrote:
What model is your ride? Does it have projector lamps?
It's C180K without Projector Headlight. Just normal type. That's why I'm thinking of changing the HID kit when I saw it at the Philips Carnival.
Guest hkhamateur
Unimog wrote:
If I add strut bar
Yeap, Bro Blackmercs was right! Which model n class? Hve been discussed earlier on this thread n few bros has tried grp buy bt....no sure e outcome! :whistle:
Feel like gettg original if AMG has or OEM tat designs similar to original. :becky:
Guest hkhamateur
mark84 wrote:
Hi all,
Just a quick check, this question might be a bit 'noob'.
The void warranty is the whole car warranty void or just the lights only?
Thanks a lot.
A big :peace: :welcome:
void all no such sector here or there. ie: ecu dwn bcoz u installed pivot volt stabilize or susp spoilt bcoz u changed lowerg spring or yr brake malfunction bcoz u changed oem brake pads/ rotors etc...:whistle:
Then i think better dont mod liao....
