Command Map Data Version
Guest Audifreak
Guest Audifreak
Hey guys,
Just wanna check what map version u guys are using in command.
I am using SE Asia 2010 (V2.0). Is there a newer version?
My map sometimes gives crappy directions. Map points turn left and the voice says turn right....happened to anyone?
  • Replies 8
Guest hannson
Audifreak wrote:
Hey guys,
happens on same maps for other makes too.
if you look closely.. there may be a small "kink" on the map it self.. which is why the voice will say the other direction.
Guest hannson
Cavell wrote:
Hi bro audifreak
If you need help on the map just give camber53 a bizzz
He will give you the best service ..
agree! he was busy last few days but should be available now :)
