Tock Tock
Guest Anlok
Hi, I'm driving a W204. I just realised recently that when I steer my car, there a "Tock Tock" sound. Don't know whether it's from the steering, ball bearing or tyres. Is that normal? Anyone experience this?
Guest jhun_4040
Bro, when you steer left ? or right ? or anywhere also will have this noise ?
Is the tock tock sound very distinctive ? can you judge where it coming from roughly ?
Did it happen when you cold start or after driving for a few minutes?
Guest joey2003
hi bro.. I had the same issue on my W203... and I brought it down to Star Black to check it out just yesterday and the problem's solved now! :D
I suggest perhaps you could check with Michael (DarkAv) and maybe take it down to Star black to check it out... it could be the lubrication or steering column or wheel bearing.. my case was simple.. just the lubrication...
Anlok wrote:
Very distinctive. Should not be from tyres. When I steer right & left, I can hear it. Even after driving for some time.
Guest hkhamateur
Anlok wrote:
How much you spend to rectify this? I should be going to C&C Ubi since under warranty.
Since u re aware of e cause, bring it dwn to C&C to resolve it. :becky:
and since yr ride re under warranty still. :hand:
Guest hkhamateur
Anlok wrote:
I can't be sure of the cause but definitely I'm going to C&C. Do they entertain walk-in?
Yes, bt they ll tell u probably hve time to diagnose no time fr repair if major work. Their time slot re v tight. :becky:
or they ll adv u tat need to leave car w them fr 1-2days maybe. :whistle:
Guest chiaster
i probably had the same sound too coming from somewhere around the steering column when making turns on slow speed... brought it to StarBlack and they rectified it for me... it won't go away totally but the sound should be negligible from thereon...
Went to C&C early morning. They detected the prob straight away but as Bro hkhamateur mentioned here, they can't do it today. Appt fixed on Tue.They're saying this is a know prob for W204.
During delivery, C&C need to remove the undercarriage cover to dunno inspect what. And W204 is the only model with a metal cover. So when they cover back, sometimes the screw alignment is out. Thus this problem occurs. Now they got to check whether is screw or the front arms of the car.
Will update you guys after Tue.
Guest joey2003
Since your car is under waranty, I guess you should ask them to rectify the screws and test... and if the screws are not the problem, i guess you have to ask them to change the front arms... it should be free as you have waranty right?
for my case.. part of the tock tock was due to the front arms and partly due to some undercarriage something that needed lubrication :P
Anlok wrote:
Said they can't be sure till they check. That is 1 possibility & another possible cause is the front arms.
Yes yes, that's what they told me too. So is your prob resolved?
Guest joey2003
Yep..the problem is resolved now... do let us know how yours turn out after your appt with C&C on tues! :)
