**Thank you- cd changer worked again***. Help Needed - CD changer
Guest Rainbow
Hi everyone,
Need some advice. The cd in the cd changer is moving as I can hear the changer, selecting the disc. But, there was no sound???? The radio and the single disc is fine, only when I switched to CDC.
Was suspecting that I might have pressed any button accidentally that causes it to mute?? Check the manual but could not find any solution. :Cry:
Can the experts share or advice?
Thank you
Hi Rainbow,
I am not an expert but will try to help.
U might want to try to select under the audio function to check is it mute.
Hope my 2 cents worth helps
:bounce::bounce::bounce:(the bouncing emoji was requested by Claudia hahah)
Had similar problem last week.
The changer could play intermittently, but could not eject disk.
Had it check by an audio shop and found out that the problem was due to faulty head unit (audio 20 I think). Replaced the head unit and things back to normal
My set is also audio 20. May I know how much you replaced your head unit?
Yap ST wrote:
Hi Rainbow,
Hahaha, send my hugs to Claudia.
I tried. But u know what, aft abt 30 mins, my dh went down to start the car. And it works again.!!
ricric_lo wrote:
Hi, may I know what's model of your ride and audio? W211? The changer may be have problem too.
Cheers, Ricky
Hi Ricky,
I am sure abt the model. Alamak, pls pls, I crossed my fingers.
Cheers, Ricky
Hi Ricky,
I am not sure abt the model. Alamak, pls pls, I crossed my fingers.
I had the same problem some time ago.
Did some internet search....
Find out where the fuse for your CDC and/or CD player is...
With the key in on position(eng. can be off), pull the fuse out and put it back.
Provided fuse is not blown.
See if this works.
