80kkm servicing
Guest snappy
Guest snappy
Hi guys,
Doing my 80kkm servicing soon. Intends to change my ATF fluid and coolant. May I know how many litres should I buy for ATF and coolant?
Also, what other things are due to change? ATF filter, fuel filter?
Thanks!
  • Replies 5
Guest Sanjay
snappy wrote:
Hi guys,
Thanks!
you going to buy the atf etc yourself and pay labour to workshop? why not get the workshop to do everything?
Guest snappy
Need to get the stuffs myself as my workshop doesn't have Mercedes stuff. They'll use after market ATF and etc. So I'd rather get the original ATF and coolant myself and ask them to change.
Guest subaru67
call see n see ask:becky:
Guest Sanjay
i believe that along with ATF, gasket etc also has to be changed... pls ask your workshop exactly what will be required.
Also, as long as ATF meets MB requirements you are fine...
