Battery weak symptoms
Guest SL63AMG
io5885 wrote:
Thks bro. Reset button is for E grass rite? The black switch knob.
C grass no reset button wor... correct?
Think he's referring to his ML & SL.
There's a reset button in the centre of the instrument cluster sitting between 2 buttons for adjusting cluster illumination.
This button to to reset mileage, reset FC since start & or reset.
  • Replies 35
Guest achuafc
As far as recalled, when my battery went kaput in the previous jap ride, the needles in the odometer "danced" a little each time I cranked the engine. It's a very unusual sort of movement compared to a good battery. This is the tell tale sign.
Precaution?
(1) Each time you send your ride for oil change, get a battery test done.
(2) When it's been 2-3 years since the battery gets replaced, it high time to think about replacing! Rather part with that $200-$300 buck than to waste time waiting for tow truck or AA, right?
Guest io5885
SL63AMG wrote:
1) Cluster digital display must be in speedometer mode.
2) Turn key to position 0.
3) Turn key to position 1 and quickly tab on reset button 3 times.
There be a beep sound and you be in the "service menu" showing you battery voltage and other info :smile:
bro,
u got a C grass in ur collection of AMGs rite..
u try liao anot?
Guest SL63AMG
io5885 wrote:
bro,
u try liao anot?
Not yet, today drive S-Class, going to see if I can try it on this car.
Later I will check on C-Class :smile:
Guest io5885
SL63AMG wrote:
Ok, tried on S & C Class, both cannot, as both use "ok" button to reset, I keep pressing ok,ok,ok... in the end still not ok :lol:
then i will not get to know my battery ok bu ok le... :Cry:
Guest SL63AMG
Go buy those battery tester will do :smile:
Think challenger got sell, rather cheap $15.00+ if not wrong.
Guest io5885
achuali there is a workshop in front of my work place.
can get them to help me test test anytime..
just thinking if can be like ur SL see from inside, then best lah. no run water.
:lol: thanks for trying out, bro.
Cheers!! :wave:
Guest io5885
I just checked my car battery after car "slept"for 5 hrs.
Reading is at 12.26V.
But hor, u mentioned abt CCA. dats wat we ought to look at, rite?
wat device to use? How to tell the batt is old n cant hold charge?
the tester from challenger or the volt reader (subaru67)??? :Cry:
Guest SL63AMG
Volt reader will only show volt, for the challenger one I not sure they still selling, it show battery CCA in 3 percentage (I forgot which 3), hopefully you can still find it.
The one I got is a battery diagnostic device about $1000+.
  • 12 years later...
Hi SGmerc, it took me longer to open and lock the car. Despite having changed my key battery (2032) and there is nothing in my pocket when opening / locking the door. Is this a sign where battery is going flat? Where should I get it check? What should be done here. Thanks
