AMG seat belt clip
As above, letting go at $10 only 8 pcs FCFS. This not bottle cap opener!! Is to clip it onto safety belt buckle when driving so that no warning alarm will be activated.
Use it at yr own risk, I won't be responsible for your safety if u didn't buckle up when driving. Those attended the recent experience are harping on the importance of buckle up when driving, so is a no go for u guys :)
If the response is overwhelming (after this lot 8 pcs) I'll bring in more stock by mid of Sept 2011. This is only a "IF" no promise as I don't do this for a living!!
1) unker batam - 2 pcs
2) lighting - 1 pce
3)
4)
5)
thanks
jtang wrote:
Another way of deactivating the alarm is to see Camber. He deacvtivates with his super laptop...5min.
He tried!......Mine cannot leh!!!
Just like Bro Lightning - wanna use it in the mscp when washing & moving the car around. Body sweaty & wet! :becky:
Guest lightning
hahaha you remember :becky: ... ya i still want to keep the warning intact to remind my front seat passenger to buckle up...:music:
Guest karilaksa
2) lighting - 1 pce
3) karilaksa 2 pcs (can fit other cars or not?)
4)
5)
thanks
Guest DIY_merc
2) lighting - 1 pce
4) DIY_Merc
5)
thanks
By doing this to 'bluf' your system might activate your air bag, so aware !
Guest Cklasse5
2) lighting - 1 pce
4) DIY_Merc
5) cklasse5 - 1 pc
thanks
Guest chershen
2) lighting - 1 pce
4) DIY_Merc
5) chershen - 2 pcs
thanks
2) lighting - 1 pce
4) DIY_Merc
5) chershen - 2 pcs
6) bac (if got leftover from the above) 2 pcs
2) lighting - 1 pce
4) DIY_Merc - 1 pce
5) chershen - 2 pcs
ok orders stop from here. Please add in yr name in the list if you can wait for the next batch incoming (if there is)!!. Order closed by end of this month 31/8/2011. Thanks
1) bac (if got leftover from the above) 2 pcs
Care to share how this can happens?? So that the buyer here are aware can make a choice & not regretting getting one. Please do share with us.
Thanks
Thanks
Our safety belt are link to the management unit , by resetting it or 'bluf' the management the belt are buckle and stop the beep be it engine on or off , this will leads to the managemnet unit go 'crazy'.
You guys had went for the Merc drive should know that if you brake real hard, management unit will off the engine, belt tigthen and window down......
Updated!!!
2) lighting - 1 pce
3) cklasse5 - 1 pce
4) DIY_Merc - 1 pce
5) chershen - 2 pcs
6) barber - 1 pce
2) lighting - 1 pce
4) DIY_Merc
5) Gab - 1 Pc
thanks
2) lighting - 1 pce
4) DIY_Merc
5) Gab - 1 Pc
