W204 tail lamp bulb blown
Guest RYANS
Guest RYANS
I've encountered few blown bulbs on the left side bottom tail lamp. Is this a common problem? My car wiring is stock.
anyone knows where to buy ready stocks for w204 LED tail lamp?
  • Replies 10
Sonic is the place. Also ask steve to check yr wiring.
Guest subaru67
w204 got led rear lamp or using red led bulb for rear?:shocked:
cos he mention bulb... so our stock bulb can change to led??
Yes, you can change the whole rear module to LED from Sonic.
Guest BlackSleekMercedes
You can easily change it yourself. The bulb costs at most $2 and you just have to dismantle the rear casing yourself from the boot.
On a different topic, I think the rear lights on the facelifted C-Class looks awesome. Anyone knows where to get it and if it fits out the present W204?
Guest chowellor
There is this issue of the module melting which cause the bulb to fuse.
Some folks out there is able to bypass this problem.
have a look at the socket, it will show signs of melting.
cheers
Guest alexclement
Yes, the bulbs contact point shows signs of melting. This week i have changed the same 2 bottom left side bulbs for the 3rd time in 6mths of ownership. Maybe should try LED bulbs... Any bros tried?
Guest RYANS
Looks like we got into the same problem.. I've ordered the LED tail lamp from sonic racing today.
