Check Engine Light on for W211
Guest blackteg
Guest blackteg
Hi bros,
I've got a check engine light on for my w211...the drive is still very smooth and the usual workshop i go to is still trying to diagnose the problem.
they have changed the 02 sensors as well as airhose but the light still came on on second crank.
they suspect might be due to wirings wear and tear or worse case ECU.
Would like to check if any of you experienced this before.
thanks man!
  • 10 years later...
