GPS Updated map for W211
Guest 9339
Guest 9339
Had recently swop a command NGT (I think so) with another car, it come with DVD/GPS no bluetooth. The map doesnt seem to be updated as i notice many road are not in it.
Need to get a updated map , where can i get it and how much does it cost ?
  • Replies 5
NTG 2 or 2.5? NTG 2.5 has a SD Card Slot above the DVD slot.
Camber has the 2011 SEA Map for NTG 2.5 - could be diff from NTG 2.
Why no BT? During the swop someone forget to take the BT connection from the back of COMAND NTG?
Randy - Get camber to take a look.
He's in Shenzhen & will be back this week Thu.
Guest 9339
Thanks Unker.
Mine should be a NGT 2 as it do not come with the SD slots and is taken out from a 2005 W211.
Will check with him.
Hoping someone is kind enough to copy it if can be done....hahaaa
