Rear Seatbelt Indicator ?
Guest aspade
Hi B owners,
Do you all have the rear seatbelt indicator function on the multi function display ? Think it's a great feature to spotcheck my kids if they have wore their seatbelts. I just couldn't see it after fiddling with all the controls.
Supposedly only available in certain countries, why not Singapore ? Or is it just my copy ?
  • 1 year later...
Guest Jean Tan
Anyone of you, have changed the tire of your B class?
My B170's tires are wearing off, my car is only two years old. Mileage is about 38,000. Anyone can answer me, is it normal to change the tire so soon? Where to get cheap and good tires change? Any suggestion? What are the things I should take care when changing the tires? How much will cost for a tire that suits B170? Don't wish to go C&C workshop! Sure expensive! Any good Lobang?
Guest ratsgoh
Jean,
Abit wierd when u mentioned about changing your tires at 38,000km. Based on my experience, tires usually last close to 50,000km. Of course, with all things being equal, you must "maintain" your tires like 10km rotation and balancing (to ensure even wear and tear between front and back), pressure check, etc. I think our tires are the "tubeless" ones it should cost around $250 per piece or so for a 17" size. PM me if u need a referral to change your tires.
James
