C200 Intercooler+ECU mod 225HP!!!
Guest cykp
ACSLK wrote:
agreed with Andrew..................
Andrew yours is still one of best FL SLK300 (231hp, 300nm), after an upgraded pulley and an ECU re-flash and can out-run a pre-FL SLK350 (272, 330nm).
cheers
actually the b20s upgrade of 7.5 sec does not have exhaust installed and is based only on an upgrade of intercooler and ecu
Is the ecu upgrade a piggy map? or remap? or rechip? :hand:
I believe it's piggy back. Understand that there will be flat spots though. Anyway I'm in the midst of getting approval from LTA for the quad exhaust first. Don't know will succeed or not.
U mean flat spots like loss of low end torque?
For the exos, if U have the necessary documents & TUV cert, I see why not they dun approve!
