B55!!!
Guest JGoh
Mercedes-Benz B-Class B55
Driven: 10 December 2010
Superbly constructed one-off prototype is well removed from the standard B-class
What is it?
The B55 is not a regular Mercedes-Benz model. Nor is it being considered for sale – not now or at any time in the future. Sadly, I should add. Because this wild take on the otherwise wholesomely conservative B-class, created by a team of trainees at Mercedes' Rastatt factory in Germany, is an absolute riot.
As its name suggests, the superbly constructed one-off prototype is well removed from the standard B-class. Having started off life as a humble B200 CDI, it has been liberated from its standard turbocharged 2.0-litre four-cylinder diesel engine. Shoehorned into its place and other areas of the engine bay is Mercedes’ recently superseded 5.5-litre petrol V8 packing an added 243bhp at 383bhp and 170lb ft more torque at 391lb ft.
What's it like?
Just how the new engine fits under the heavily sloping bonnet and within the tight confines of the compact MPV using the original mounts and without any modification to the standard steel body structure remains somewhat of a mystery, but with polished chrome inlet plumbing and other visual tweaks, it certainly looks the goods.
It sounds it, too. Turn the key and you’re treated to a deliciously throaty soundtrack thanks to a new exhaust system created from various replacement parts that does without the usual silencers and back pressure reducing trickery. If you didn't know, you could be forgiven for thinking it was the product of AMG, which apparently had no direct input into the new car.
The engine is not the only highlight. Mercedes' trainees have also ditched the B-class's front-wheel drive layout for rear-wheel drive, running a propshaft from its new seven-speed automatic gearbox under the flat floor towards the rear where it mates with an axle from the old E430 Estate; Its 1540mm rear track allowed them to retain standard rear bodywork but required new pick-up points for the rear multi-link suspension and a smaller fuel tank.
To cope with the increased performance, it also adopts the brakes from the decade-old C32 AMG with 345mm discs up front and 300mm at the rear. Because of the limited development, though, there's no traction control or stability program to corral the engine's reserves.
The result is a driving experience quite unlike any other B-class – unlike any other Mercedes, for that matter. Without registration for road use, we used the Rastatt test track to determine the B55 is more than mere show. It also possesses surprisingly mature dynamic properties.
With an extra 15kg placed over the front axle compared to the B200 CDI, weight distribution definitely favours the front end. But there is sufficient balance and grip to allow you to attack corners with real gusto. Apart from a lack of self-centring with the steering, whose packaging has been compromised by the need to give up so much space to the engine and thus runs a smaller hydraulic pump than is perhaps required, the B55 also steers accurately, rides with impressive comfort and is free of any obvious vices.
With a kerb weight of 1620 – 180kg more than the B200 CDI – it is decently quick in a straight line. Andreas Wurz, a foreman in the technical vocation training department at Rastatt largely credited with the idea behind the new car, reckons it should be good for 0-62mph in under six seconds when he finally gets around to strapping some measuring equipment to it. He's lying, of course. This thing will easily run in the low five-second bracket.
The B55 looks rather striking for what is essentially a high-powered MPV. As you can see, Mercedes' team of trainees managed to package the new engine and driveline without any obvious changes to the standard B-class body – a remarkable achievement given the major driveline modifications that have taken place underneath. But with a lowered ride height and 18-inch wheels – 8 inches wide up front and 9 inches at the rear, shod with 235/40 (front) and 255/35 (rear) profile tyres and two centrally mounted chrome tailpipes it possess a much more aggressive stance than its standard sibling.
Should I buy one?
Sadly, though, it'll never progress beyond this prototype. But with a new, second-generation B-class due out at the Frankfurt motor show in September, it is a fitting way to send off the first-generation of Mercedes' popular compact MPV.
by Greg Kable
Price: na; Top speed: 155mph (limited); 0-62mph: 5.2sec (est); Economy: na; CO2: na; Kerb weight: 1620kg; Engine: V8, 5461cc, petrol; Power: 383bhp at 6000rpm; Torque: 391lb ft at 2800rpm; Gearbox: 7-spd automatic
Is Mercedes-Benz's One-Off Creation Onto Something?
This is the B55, a silly one-off project by workers at Mercedes’ Rastatt plant that involved shoving an old “55″ AMG engine into a new B-Class, running a driveshaft through the “sandwich floor” and hooking it up to an old E-Class wagon rear axle. The result: 383 HP, a 0-60 time in the 5 second range, and what Autocar terms “surprisingly mature dynamic properties...
Possibly even more surprisingly, the whole project was done without a lick of help from the nutters at AMG, and required no frame modifications. Best of all is how comfortingly old-school the project is: the days of turning an FWD compact car into a V8 RWD beast are rapidly drawing to a close.
Need proof? For the next-generation of A/B-Class, AMG is going in a very different direction, creating an “A25 AMG” which will use a two liter turbocharged four-banger, putting around 300 HP through a dual-clutch transmission and Haldex AWD.
This “STI by AMG” will doubtless be infinitely more practical, efficient and useable than the B55′s old-school V8/RWD setup… but more than a few gearheads will be sad to see these kinds of unhinged anachronisms ride off into the sunset.
Seems like this is a product of some 'internal' competition of sorts going on inside MB (vs AMG), to practically demonstrate what is possible to achieve from scavenging current parts bin, plus employing 'old-school' V8 up front driving fat wheels out back!!
Doesn't this make you really want one - for posterity?!?
