Advise Required
Guest ericlim1338
Guest ericlim1338
Hi All Merc Lovers
Currently driving a W211 for 6 months already. Regret giving up my W124.
2 fault code detected, can any kind soul out there advise what are these faults all about. Car is under warranty by another third party workshop, but they are not able to determine the fault after last visit.
1. ESP indicator inoperative - What is this???
2. Run Flat indicator inoperative - had checked tyre pressure but still getting this message
Thanks.
  • Replies 22
ericlim1338 wrote:
Hi All Merc Lovers
Thanks.
Dun regret! Solve the problem & go & enjoy your new ride!
Drop by our site sponsor MBM and let them take a look!
For the Run Flat Indicator Inoperative - U may wanna try restarting your
Tyre Pressure Warning System.
Good Luck Bro!
Taken from the W212
Restarting the tyre pressure loss warning system
Restart the tyre pressure loss warning system if you have:
•changed the tyre pressure
•changed the wheels or tyres
•fitted new wheels or tyres
Before restarting, consult the table of tyre pressures on the inside of the fuel filler flap to ensure that the tyre pressure in all four tyres is set correctly for the respective operating conditions.
Observe the notes in the section on tyre pressures
Make sure that the key is in position 2 more in the ignition lock.
In the multifunction display you will see the standard display more.
Press the < or > button to select the Service menu.
Press the ^ or v button to select Tyre pressure.
Press the OK button.
The multifunction display shows the message:
Run Flat Indicator active Restart with OK
Run Flat Indicator restarted
After a teach-in period, the tyre pressure loss warning system will monitor the set tyre pressures of all four tyres.
If you wish to cancel the restart:
Press the Return button.
or
If the Tyre press. now OK? message appears, use ^ or v to select Cancel.
The tyre pressure values stored at the last restart will continue to be monitored.
To see more go this this link for the W212 - should be applicable to your W211
http://www4.mercedes-benz.com/manual-cars/ba/cars/w212/en/in-depth/d10e53942.shtml#d10e53953
Is under warranty but yet couldn't get it resolved by them & u walk away? Care to share which workshop & name of the warranty party. Pls post here, so that we can avoid them.
Till date, hv u seek second opinion yet? Better get it resolved.
Bro! U fierce arh! :becky:
U think go bang table, they will send the car to C & C arh?
Wait they send to other workshops try here, try there and cannot fix how?
Think our Bro quite down after spending time to get the problem solved.
Maybe to tell the warranty party that he bring his ride to MBM to solve problem and they bear the charges.
Knowing MBM, dun think they will charge if they cannot solve the problem.
Guest ericlim1338
Thanks Bro, the procedure for retarting the tyre monitoring is interesting, I will try after i got the car back, just sent the car to the F... workshop.
I have checked with a few mechanics and read some threads elsewhere, and it seems like the problem is caused by the Steering Wheel Angle Sensor
Have told them about it and wonder if they are replacing the parts.
Cheers.....
Anyway I still enjoy my babe. - 6 secs to 140 haha
Guest ericlim1338
Blackmercs
No names shall be mentioned to protect the innocent. I am losing confidence in them anyway. A little bit of hint
They sell extended warranty located near LTA... thought they are good and confident.. but in the end just sucks.
Fews months ago send my Peuget 407 to them for top overhaul and after that the car keep stalling, send back them them and they took 1 week to check and come back wiht no problem. Send to them again and took them another week. SHIT..... the car kept stalling. Worst till the first time it stall, it was at a slope and the brake also malfunction, end result crash the back of the car on the wall lor..... :-(
No choice liao, send to agent and took them 5 days to come solve the problem. WOW LAO, I was told that there is a missing part, the timing belt pulley stabliser was MISSING. What the hell are they doing........... just LL lor. Anyway problem is solved now and enjoying my babe2 too.... hehee.
Let pray hard that no missing parts after they touch my babe today.....
Otherwise I think I will go BANG BANG BANG....
Cheers.
ericlim1338 wrote:
Cheers.....
6s to 140.....must be AMG55 or AMG63 or else where got TPMS....got prize for guessing or not.....hahaha!:becky:
If U wanna to BANG BANG BANG - I would suggest U get Bro Blackmerc along!
He's our forum Mapia, Yakusai, Sumseng Kia, Pai Kia, SMLC Kia.....He's bigger and got more muscles than most of us!
Hope U got your problem solved!
Pls keep us updated!
ericlim1338 wrote:
Hi All Merc Lovers
Thanks.
Hi eric,
PI?
some time buying car (luck play a part so hope you can get it solve and enjoy it)
cheers
g8crasher wrote:
:whistle::whistle::whistle:
Interesting W124 6sec to 140.......
Top speed @ 280km ?
Ok, back to topic,
Buying those extended wty are just any way for the dealer to make you sign on the dotted line.
Your 1st problem - 90% due to the sensor.
2nd problem - You have to get it reset if , tyre punctual, change in size of rim/tyre ect.
Hope this help....
Just curious, are you driving a W211 E320/350 now ?
Recently saw a unit for sale.....
Guest ericlim1338
Thanks. guys
Look like getting close to the answers liao,
problem 1 - sensor
problem 2 - never change anything lia, no puncture also, don't know why like that
have been drving it for almost 6 months with no problem at all leh.
oh my mine is a '06 E200K Kompressor
Thanks guys for the advice, have been sitting in the office whole day for the workshop to call, sigh... still no answer from them,..........
Guest sanity2010
I don't mean to gloat on the problem that you have, but I am feeling better that I just finally bought my W212 from C&C... good deal at the moment..
ericlim1338 wrote:
Blackmercs
Cheers.
Guest lightning
bro sanity2010...welcome to the W212 club...what color and model you booked...when can you expect delivery? ... do join us in the mthly GTG...cheers :whistle:
Guest sanity2010
Thanks! the people in this forum helped answered a lot of questions, especially on PI.
Got Paladium Silver/Black Interior E250 Avantgarde (actually wanted Iridium but 2 units sold out on saturday :-().. hopefully by 3rd week of sept delivery, will try to join up for sure for the monthly gtg..
Guest lightning
...nice color combination...must be very excited and counting days...confirmed COE i suppose...cheers :whistle:
Guest sanity2010
C&C have this up to 6 bids clause... but SE told me should be ok by this or next round of COE.
What happen after 6 bids still no COE?.....hehehe!
I told the SE when I was offered that - "Gimme your open cat COE & I sign the deal with all the conditions earlier agreed!" Got my COE - Got my car <3 weeks after signing the agreement.:becky:
Guest ericlim1338
Well well well, my problem was finally solved, They changed the Brake Switch and all the error message gone, it seems like it is related.
Sanity - Congrads to your new 212.
Well, I have 2 cars and 1 Van - E200K Kompressor and Peugeot 407, Toyota (for marketing)............
Seems like I got to do some upgrading soon, the next car I have in mind the the S300 or S350, please comment on the performance for this model. Really exicted about it.
Guest sanity2010
Now it gets worried, UNKER!!
She did mention they might use Open Cat if need be... fingers corssed will know by next wed.. I am sure she also keen to get final payment :-) to meet quota..
Guest sanity2010
Thanks!!
Also good to know brake switch causing those weird issues...
congras!! Shld continues enjoy yr ride!!
Mind sharing how "good " was the deal? I am keen too!!
Wish U good luck!!!!! :hand:
