Catalytic removed from exhaust
Guest ahwei
Guest BenzModz
ahwei wrote:
I don't reali get wat u mean?mind to elaborate ?
If you remove the cats then the 0xygen sensors will throw a fault code beause your cats are missing. To overcome this fault code you most likely need to remove the oxygen sensor reading from the engine controller software.
I have only ever seen it once before and it was on a hand-built W208 AMG Rally Car.
How do you do it ?
