Interest check on Retrofitting Command
We could be arranging another oversea installer to instal Command in Singapore.
Prices for the Command will be probably be $3.5K above including installation depending on car model and the number of cars to be retrofitted.
If U are interested pls put your name below:-
Though it's not a confirmation but please be serious about it before putting your name down.
Thank you for your kind understanding.
1) kepiting1sg - W212 E250 Avantgarde - Command
2) kepiting1sg - W203 180ML - Command
3) bac??? - W211 Command??
4)
3) bac - W211 Command
4)
Thanks.
4) 9339 - W211 COMMAND YOM 2004 ( check what's the price first )
Thanks.
Thanks.
Interest check nia!
Not reliable! I dun wan!
Too $$$ I also dun wan!
Interest noted!
Guest DIY_merc
kepiting1sg wrote:
Interest check nia!
Interest noted!
After the upgrade, can the LCD shows chinese characters ?
kepiting, I thought you already TV, Navigation etc. Why upgrade to command ??
The current Audio 20 has only a 5.8" LCD screen.
Command comes with 7" higher resolution LCD screen.
It has linguatronic voice control.
I want the original DVD.
I might want to intergrate my after mkt with the command too.
The command has 40Gb HDD with PCMCIA for SD Card.
I want more choices......hehehehe!
U should see Cerano retrofit Command!
Very impressive!
Guest DIY_merc
Very impressive!
how do you watch your TV, reverse camera and do your navigation after the command upgrade ?
can read chinese character or not ? lots of chinese songs leh :becky:
Thank you !
Guest dav1dyeo
I'm in. not sure if I'm doing it right, anyway i added mine to the list below
4) dav1dyeo e200 coupe - command
Guest Raydon
I have actually confirmed my interest with Cerano aka Zacc but anyway i will just list down my interest below as well :
5) Raydon - W204 -Command + reverse cam + VIM + Linguatronic
6) Raydon - W212 -Command + reverse cam + VIM + Linguatronic
Hi Bro dav1dyeo,
May I know your model and year please?
Hi Guys,
I would keep this list for another week and probably I will closed
the interest check and get to the installer for quotes!
If you want Linquatronic voice control, please let me know.
I guess it would be appropriate for W204 & W212.
Not sure about W211 & W203!
Bro Cerano,
Any updates from your side?
Pls contact me!
1) kepiting1sg - W212 E250cgi Avantgarde (MY2010) - Command + VIM + Linguatronic Voice Control
2) kepiting1sg - W203 180ML (MY2003) - Command + VIM
3) bac - W211 E200ML (MY2003) Command + VIM
4) 9339 - W211 (MY2004) Command + VIM
5) dav1dyeo e200 coupe - command + VIM
6) Raydon - W204 -Command + reverse cam + VIM
7) Raydon - W212 -Command + reverse cam + VIM
Thank you !
Cannot read Chinese lah!
Hoping the cable for Audio 20 & Command to the screen is the same.
Then I will be able to add the after mkt mmi to the command like at present.
If not, then probably I will add the garmin gps+ dtv to the command (IIRC there are 2 av inputs if not using the reverse cam)
Wanna join us?
Guest DIY_merc
Wanna join us?
have to think harder lah. Don't wait for me. Thanks for the info. :becky:
Guest BenzModz
For W211, W203 there is more than one option.
The W203 has 3 options
However, the W203 BOSCH Comand 2.0 from 2000-2004 does not have a Bluetooth option. It is a D2B system and is too slow for the BT processing of audio which gives feedback and echo.
If you want 2005-2010 Navigation you have the choice of NTG2 or NTG2.5 - there is a huge difference in the functions but the design is very similar.
To install NTG2.5 in 2003 W203 it must involve replacing all the wood in the centre console, the buttons panel and the AC panel. The new COMAND frame must be installed after the dash is removed.
The bluetooth will work fine but the BOSE / CD stacker and other D2B appliances no chance to work. Those have to be replaced totally. You will also need a new cluster in some cases. Depends on the exact year model.
The W211 has 2 options possible. One is NTG 1 (original type GPS) and the other is NTG 2.5 (2008+ GPS). To install NTG 2.5 the car MUST NOT HAVE Harmon Kardon. You lose the old CD stacker and you lose the old phone kit.
The ideal car for NTG 2.5 is one with almost no options and just audio 20 radio from late 2003 and later. Early 2002 W211 are difficult to modify. They require many more parts than the later model cars.
We can generally assume that in some cases it will be easier to install the older version GPS and have the compatible functions.
VIM = with NTG 2.5 will remove all GPS functions because it cuts the antenna signal and the CANBUS signal to the COMAND. So if you are navigating then you have no chance for VIM in this COMAND.
Alternately, the NTG 2.5 has excellent support for rear screen. Almost any type of rear screen can be used with the COMAND NTG 2.5.
I only recommend you use Mercedes parts. They are designed to work in a Mercedes.
Hi Miro,
Would you think it's a better idea you deal directly with each of the car owner here, so that you can have a better idea what are the options and features they really want? Then you consolidate all the "orders" before you come here.
Or would you prefer to go through a co-ordinator like Cerano aka Zacc?
All of them would want to have at least Bluetooth Telephony, Navigation with the latest 2010 South East Asia Navigation Maps, DVD with VIM.
The current list is as follows:
regards
KP Seah
Guest BenzModz
I will do my best to give you the correct advice. I dont expect you to buy all the items from me but in the past I have had some good sources.
I will assist questions as best as possible.
Guest arsenal
Hi Miro,
Need to check with you it is possible to upgrade/change CL55AMG W215(year 2000) existing HU to the latest or can fix the below problem.
Now this car HU GPS (according to my friend its using disc) is not working and built-in car telephone also down.
If require to replace HU can it be converted/upgraded to have bluetooth function and delete the built-in car phone?
Thanks
Guest BenzModz
I have requested a set of prices for all the cars listed below. All of them except the W203 are going to be easy enough for us to make up a kit.
The VIM you must know it can switch off the GPS function. So when you have VIM there is no GPS.
Arsenal, the W215 only has 3 head unit options.
- 2000-2000 4:3 CD D2B
- 2003 Widscreeen CD D2B
- 2004-2007 Widescreen DVD MOST
To convert W215 2000 to W215 2005 starts at 20K. It requires the whole interior removed and about 3 days work.
The car is just empty inside so the wiring can be done. Then after the wiring you also have new seat modules, new centre wood, new phone kit. New door modules, new fuse boxes, new igntion switch, new cluster.
One customer in Germany is believed to have spent about 35K to install 2010 navigation into 2000 W220 S-Class. This installation is really one-of-kind. It was done in Germany.
It comes down to price. There is absolutely no problem with installing the parts.
Guest arsenal
Hi Miro,
I think my friend's W215 is the 4:3 CD D2B type. The disc loading slot is on top of the screen and keypad is on the right side of the screen.
Wow $20k as a start for convertion for wide screen DVD!!!
What is the $$ damage if want to make good to original i.e. GPS and built-in car phone in working condition?
Also if want to change to wide screen CD D2B what is the cost?
Thanks.
Guest BenzModz
arsenal wrote:
Hi Miro,
Thanks.
The installation of the parts is about 20 hours. The cost of the wiring harness is about 1500-3000 depending on options added. The parts themselves depend on the market. Look to spend about 8K to 12K for a full 2003 rewire.
Guest BenzModz
resol2000 wrote:
new to merecedes and just got my B180. Can the B180 be fitted with the command APS with VIM and Reverse Camera?
what will be the cost?
There is no factory solution for W245 B-Class rear camera but one can be designed using Mercedes parts.
Guest BenzModz
Cerano wrote:
Hi Guys
Yes I am helping to coordinate Comand installations.
Pricewise as mentioned differ but we're looking around close to 4k or high 3ks
cheers
Every single car will have a different price depending on Chassis number and options requested. Some of the options listed below are high than 4K.
