2010 Comand APS Map
Guest Cerano
Guest bbwannabe
Addon:
I believe Cerano needs the COMAND APS Nav disc for his W204. ALL navi disc colour coded Purple should work. GL-class uses this disc too.
Also, for those who have the COMAND APS for W211 (last gen, brownish menu instead of bluish) report in too! It is colour coded Yellow. Models like A, B, CLC, CLS, G, R, M, GL, SL, SLK also use the same disc.
For more reference, Click here.
Guest bbwannabe
carnipotent wrote:
I would also need navigation dvd version 2008 (NTG1) B6 782 3880. Can anyone direct me to where I can get this?
oh... basically the green one for w211 ah... haha... well... 2007 good enough for you?
Guest Cerano
no la because
the disc... mitesh can handle but need top up mah. and i read previously that bros here have the map since its 1 time use not much use buying leh
Guest carnipotent
Bro, I have w211. Car registered Jun 2007. Is it the same 1 you are referring to? DVD does not include all the new expressways like kpe etc. If yours is newer, then definitely better la..:becky:
Guest bbwannabe
lol... bo bian i got the 07 one also. sian.
i must say right, the GPS is actually quite good. it thinks like me which is better than my garmin. i have the comand aps, garmin 660, android google maps in my car. google maps is pretty good but i only use it before i start the trip. when i'm not sure where i am, the comand is pretty accurate as it keep track of direction better. (tracked location is all the same but direction on comand is better)
it also gives better direction! it is like me, prefer expressway (dynamic route) while my garmin (fastest route) always drive me through random little streets.
if only the map was updated.
Guest bbwannabe
Cerano wrote:
no la because
hmmm... actually. if really don't have. then lan lan all pool money and share!
Cerano wrote:
but damn ex is it? haha
fwah! go & buy 1 lah!:becky:
Wait later again out of date how?:whistle:
Tmr where are U installing the stuff?
- see can find time cum and kaypoh a little.
Guest Cerano
unker we postpone to the 27th sgmerc gtg then he come over
Guest carnipotent
Europe Nav dvds are readily available and pretty cheap too. But finding the ones for South East Asia use is like looking for a needle in a haystack. Btw, how much is it for the original? I do not mind sharing if not too ex..
Guest Spidy
Anyone has the SEA map version A169 827 68 59 ? Willing to share (or sell) ?
Otherwise who want to pool money for SEA map ?
Mine is W203, according to the manual (see link below) the same map can be used for :
W/C 169 - A-class
W245 - B-class
W/S/CL 203
A/C 209 - CLK
G 463 - G-class
W/V 251 - R-class
W 164 - M-class
X 164 - GL-class
http://e-sklep.warszawa.mercedes-benz.pl/themes/Mercedes/download/nawigacja.pdf?SSID=xfiqlhnqr
please PM me if you are interested.
Guest bbwannabe
W/C 169 - A-class
W245 - B-class
W/S/CL 203
A/C 209 - CLK
G 463 - G-class
W/V 251 - R-class
W 164 - M-class
X 164 - GL-class
fwah~ so much updated than the one i found (includes 2010!). damn pro at googling.
Guest JGoh
Hi Guys. Thanks so much for initiating this thread.
I am also in need of an update for my Command APS, and based on the helpful link to http://e-sklep.warszawa.mercedes-ben...SSID=xfiqlhnqr, the DVD for my CLS would be:
Navigation DVD Southeast Asia Version 2009 (NTG-1)
A211 827 27 65 Green A4
compatible for:
W211 E Class from 2002 to Jul 2008
C215 CL Class from Sep 2003 (VIN A040478) onwards
C219 CLS Class from 2004 to Apr 2008
W220 S Class from Sep 2003 onwards
R230 SL Class from Jul 2004 to Apr 2008
R171 SLK Class from 2004 to Apr 2008
I would be happy to Share costs for the DVD with anyone/cars as listed above, with COMMAND APS, or,
if Cerano/Mitesh wishes to take on this exercise?
Cheers!
Guest bbwannabe
compatible for:
Cheers!
+1, me if you want to get the 2010/2011 map!
Guest bbwannabe
lol... crap. should be clearer.
i meant count me me in if you all GB-ing.
so add your names here!
gb for Green nav disc for w211 (and compatible):
1. bbwannabe
2. JGoh
Guest Cerano
no prob we understand
1. bbwannabe
2. JGoh
3. Marcus
