Fisocn pro - bt solution for your mercs
Guest blackknight
jsiau wrote:
Uncker
Good news .. went to activate and try the A2DP it works beautifully, the iPhone plays and connect well all the songs .. Bad new after I deactivate the A2DP and try to use back my 6 piece original CD changer from W211 ...it disappear from the system.. try deactivating again and again....the CD changer still doesn't come out..... see liao , ...anyone can help or tell me what is happening??
sometimes the Fiscon like to play hide & seek....muhahaha!:lol:
It happened sometimes to my previous Q5 too.
Maybe try re-pairing your phone again!
BTW S'pore beri small place!
Today having lunch saw Bro Camber53 working his a#$s out on a Sunday!
Try to unpair and master reset also cannot, jia liat liao........anyone can help SOS
mongyh wrote:
Hi jsiau, can you share more oon Fiscon installation? thanks
BTW , did you PM me I did not rec... anyway I do not have the full questions from you and can only assume your ride is a MERC and you are either having Audio20 or Audio50 and Comand APS (pls. note that it is not suitable for cars with Comand APS NTG 2.5 , the one with the SD card slot) if you are having any of the three above than it is possible.. pls. read the thread above and you probably needs to do coding for your car... and pls see link below for Ficson BT
http://www.fiscon-mobile.eu/products/pro_mercedes.php
Regards
Guest camber53
Hi all bro
If you are interested to install fiscon pro your ride can
Email me or call thank you
Gregory@ sinceresystem.com.sg
96680053
Car Compatibility
FISCON Pro handsfree kits for Mercedes are compatible with these cars:
Supported Cars
A-Class W169
B-Class W245
C-Class W203 from 04.2004
CL-Class W215 from 09.2004
CLK-Class W209 from 06.2004
CLS-Class W219
E-Class W211 from 03.2003
GL-Class X164
ML-Class W164 from 06.2005
R-Class W251
S-Class W220 from 09.2003
SL-Class R230 from 06.2004
SLK-Class R171 from 03.2004
Viano/Vito W639
Radio / Navigationssystem
Audio 20
APS50
Comand NTG1
Comand NTG2
It does not fit for Comand NTG2.5 (it has a SD-Card slot close to the CD drive), Comand NTG3 and Comand NTG4.
