Repairing Electric parts of my W140
Guest sunnytang7788
Guest sunnytang7788
Dear All,
I need to repair the followings in my W140 (1993 version pre-facelift) and appreciate advised where I can do it economically:
1. The electric seat button on the driver's side is broken, glueing back is only a temp solution as it always keep coming out. Not the memory version.
2. The back inclining and heat rest of electric seat on the front passenger are not functioning, it can now only moved front and back.
3. The rear sunshade and driver side window button are sunk in and needs to be fixed back to the original position.
4. The rear headrest funtion no longer funtioning, the vaccum pump not sure is spoilt or cable loose.
5. The rear central light is not funtioning 100%, sometimes it can be lighted while not 100%. I understand it is the contact may be loose due to the sponge that is already old, I tried to put another sponge to tighten the contact but still not effective.
My current mechanic is good only for the engine part, thus I need a good workshop to fix the above electric stuffs and not sure if spare parts are available.
Appreciate you can recommend a good workshop. If you are the workshop, you can PM me.
Many thanks.
Sunny
  • Replies 4
Guest YEN96
wow. rare car now. W140 nickname big water cow hahaa....
SMS me if u need any spare parts for Mercedes Benz! If u have the part numbers better still.
9362 3352
  • 1 year later...
  • 2 years later...
