Warning -Goodyear F1 Asymmetric sidewall found crack
Guest lightning
Guest lightning
For those who are using Goodyear F1 Asymmetric tires, my advice to you is to have them check. http://www.sgmerc.com/forums/showthread.php?p=126030#post126030
FYI, I went for the inspection today at City Tyres and BOTH of my front tires (3 mths old - 225/40/18) were found to have cracks. :Cry: :shocked: The Goodyear company has agreed to replace them FOC... :whistle:
was thkg to replace my F1 eagle to the F1 Asy but discover alot of same complain heard from other forums looks quite serious...... another quality problem.....
Guest lightning
xtrocious wrote:
Wah, I am also using Goodyear F1 Assymmetric :(
Question - can we (layman) spot these cracks or do we need to send our cars down to a tyre shop to check?
The cracks are found mainly on the inner side of the tyres, so they need to hoist up your car to check from the bottom...suggest you call up the Goodyear S'pore, to book an appointment with City Tyres at Sin Ming Autocare for inspection. Call up Simon Awe, the Business Mgr of Goodyear Sg at HP: 97554388. If your F1 Asy tyres were mfg in 2009 and size: 225/40/18, high chance there are cracks on them. Good luck...:whistle:
Guest xtrocious
Oh...like that ah :(
I am using 225/40/18 and 245/35/18...
Not sure when was the manufacturing date though...
Thanks bro - will call him up to check
Anyway, I just called the shop (KBS) from which I bought my rims and tyres - they said they are not aware of this issue nor has anyone made any complaint...
Said they will call me back (but I won't hold my breath) once they check with their management...
Guest lightning
Bro...you collected your car and changed your rims/tyres late last year so most likely the mfg date is also 2009... I m also on staggered... but my rear 255/35/18 has no problem... for peace of mind better go for a check...FOC inspection anyway...free replacement if found to have cracks...:becky:
It was discussed quite extensively in the VW & Audi forum...believe also in the BMW forum... from what I read, it affect mainly 2 models, i.e. 225/40/18 and 235/35/19...the cracks are very thin (hairline) but you never know...let me know the outcome...:whistle:
Guest xtrocious
Thanks bro
Guess what? KBS just called me back - they told me to send my car down for a free check anytime and they will replace the tyres for free if they find any cracks :)
Will probably do it next week - swamped with work this week :(
By the way, some Audi guys pump their tyres up to 42psi and they found them to be okay...
What pressure are you using for yours?
I think I am using 36psi for all my tyres
Guest xtrocious
lightning wrote:
i usually pump 220 - 230 kpa or 33 psi :whistle:
So my ride's harder than yours...hahah
Can't imagine pumping 42psi though - might as well be riding on beemer's flat runs already :P
Guest kinky74
Hi guys there seems to be a crack in on front right tires...should i go to C&C for complaint and exchange or any particular place to have it change? oh mine is a agent car.
Guest Luci Ride
If it's supplied by C&C then yes pls do revert back to them immediately, however doubt they've supplied you said brand/model hence better to go back to shop whom you've purchased.
There's a few batches that are not up to par in terms of quality but however by & large there's equally more that are perfectly ok- was running on 2 sets before selling ride off (18') hence wondering what's all the fuss is about (kept checking approx once weekly & used it ROBUSTLY)
