Brake Wear Warning Sign
Guest notti
Hi folks,
Any of the b classers here experience the above?
Cycle quoted me $500 plus, any authorised workshop to change the brake pads to recommend will be highly appreicated :)
Btw, anyone knows how long will the whole process take?
notti wrote:
Hi folks,
alot of workshops will be able to do brake pad change ... but I am not sure if one needs to be reset the warning message or it will go off once new pads are in ? Would not take more than an hour to do .. check with MBM for $$$ ?
notti wrote:
Hi folks,
I had just did mine at MBM, took less than 2 hour and $$$ is less than you are being quoted.
Give Chole from MBM a call, this pretty cute babe will be happy to answer all you ???
