white light for rear plate
Guest jan999
jan999 wrote:
no one can advice?
by the way, i saw many of Merc changed to a whiter bulb for their 'small lamp', if i anyhow use any bulb, would it give me any error code as well?
for the smaller bulbs...only u use the LED type then would give error code..if not just change to the more whiter type rather than yellowish .....If you intend to change to HID for the H7 low beam then you need a HID cancellor
Guest lightning
jan999 wrote:
no one can advice?
contact Steven at 96392988...he will solve your problem...:whistle:
