Garmin Problem
  • Replies 3
ok, after some searching heres what i've turned up.
theres a work ard, but its damn long and tedious. and if u accidentally hit the stop button, good game to you.
1. select your final destination and GO
2. select your 2nd last dest and hit set as via point
3. select your 3rd last location and hit set as via point
4. etc etc, keep working backwards.
I know this isn't "true" routing ... but you could set up three or four addresses as "via's" and get multiple distination routing.
I plan on using it to "force" the GPS into swinging down a couple of stops as I head from say west coast to east coast... which is kinda rubbish considering that i should be able to set mutliple way points as a route and save it somewhere so i can use it for a holiday...
