air con....
Guest jan999
can anyone tell me for CLK air con mode, is it by default that set at non circulation mode? mine is like that. then have to press on it to activate circular mode if not if a lorry in front me, i can suffocate with all the waste gas coming in cabin...
and also, even i activated the circular mode, it will turn off in a while like 20 mins, then i have to turn it on again...
meant to be like that? or something wrong???
also, there is a button with 2 arrows pointing to the right. a solid white arrow then || a hollow white arrow. what does it serve? thanks
  • Replies 3
same prob is faced on all merc models bro
regulated by the thermatic system. every 30mins it'll switch to outside air to prevent CO2 poisoning
