battery replacement
Guest jan999
  • Replies 4
my battery almost dying, can i go any shop to replace or must bring back to C&C?
any special note need to be taken if go outside shop?
U dun have to go to C & C.
If U need to buy 1 from outsie, ensure it's of the right capacity in terms of AH (Ampere Hour)
If U are an AA member, just give them a call and they will replace for U straight away on the spot($200+ Brand Hoppecke - German - Good battery)
can i use DIN88?
coz service centre said should be DIN66, but outside garage said that it should be DIN88...
IMHO the main difference is Din 88 is rated @ 88AH capacity or higher capacity than Din 66 which is rated @ 66AH.
Should not pose any problem with a bigger capacity battery other than weight, dimension and provided it can fit into your stock battery tray.
some references
http://www.centuryauto.com.my/century-gold.php
http://www.namwah.com.sg/index.aspx?uc=products_prodlist&CateID=100
