Help!! Radiator Leak on W124! :(
Guest mercw124
Guest mercw124
Hi Guys,
Currently having a radiator leak on my W124, the water's dripping from the area around 15 cm away from the centre portion of the front bumper.
Anyone knows the approximate cost of rectifying this problem?
Hope it's just the hose that's leaking!
Guest mr w124
Check the connection of the bottom hose to the radiator. mine had that prob too n i would find coolant at the undercarriage cover. the connection was loose. you can tighten it yourself with a scredriver but be careful not to damage the threading on the screw.
