How to remove cigarette smoke smell from Air Con
Guest E200
My 124 smells of cigarette smoke coming from the air con, ever since I took over. It's been some 4 months now, and though I had put in air fresheners, still the smell. Also put those charcoal-based odour absorbers ... still same problem.
I'm thinking there must be something that I can do to the air con.. can someone recommend what can I do at which workshop? Thanks.
Guest alumetal
This happen to me year ago.
2 method
a) do a 100% chemical clean (jus like yr house air-con) on the air-con sys..... it will be alright afterthat.
B) temp solution...... put couple bundle of "pandan" leaves in the cabin ..... the smell will be gone.
Hope its helps.
edit : found a cheap source http://www.clubhyundai.org/f/viewtopic.php?f=28&t=57880
2 method
Hope its helps.
Bro,
1. How long does it take to do a chemical clean?
2. How much $$$ does it cost too?
TIA
