The mystery of the 5 speed automatic
Guest sociex
Guest sociex
I was under the impression that all FL SLK200s come with a 5-speed automatic transmission. However, I have thus far been unable to manually shift up to the 5th gear (shifting up from 4th lands me in "D"). Not sure if a certain speed is required to manually shift to 5th gear, or if I am the not-so-proud owner of the world's only 4-speed SLK??!!
  • Replies 11
Guest NewC180
For my W204, when you shift to 'D4', it means that the gear will move up to the 4th gear, which doesn't mean that you are now in the 4th gear (you could be in 3rd or 2nd). So when you shift up, it will shift to 'D' instead of 'D5', which means that the car will use all 5 gears. Dunno if this is the same as in your SLK. Hope info is of help.
hahahaha... dude ALL merc cars with S & C near their gear shift will not show the "final gear" be it "5" or for those with 7g, "7".
u can be sure ur car changes to 5 gear in D, drive until >80kmph in gear 4, if urs is an slk200.
at abt 90km, shift to D, and dun floor the pedal, u will see ur revs drop as ur car switches to top gear.
for car with pedal shift and the S / C / M, in M mode u should be able to see ur final gear...
yea as quote by willy, mine with pedal shift shows 5th gear..
Guest Sareve
Hi sociex,
time to upgrade to pedal shift steering ya............(MTL)
cheers
I'd too would like to know if it's possible to retrofit paddle shifters and have them work as they would in a car that came with them. I often find myself attempting the press the non-existant paddles when I wish to change gears.
Hi Sociex / Daniel,
i thought for SLK280, pedal shift is a SOP items?............
Yes you can buy a steering wheel with pedal shift...check Benzline or MBM or C&C...........
* thanks Eric for the explaination (MTL)
cheers
Guest Sareve
Hi Sociex / Daniel,
cheers
What's SOP stand for? I know I can buy a steering wheel with paddles, but the question is, will it actually work the way it's intended to just like in a car that actually came with them?
SOP = standard operating procedere (i thought you went army already???)
Pedal shift is an option item for non-sports package so probably have a check with the mechanic before install the best......
cheers..............
