2nd hand C180 CGI W204 1.6L (Coe-ed car)
FCMB
hi gurus,
i am looking to have my first taste on conti, and shortlisted it to c180 CGI W204 (COE-ed), that is within my budget.
if i were to make a viewing , what are the things to zoom in, for for such an older W204?
is the maintainace  going to burn a hole in wallet for this model?
and common issues for a the older w204, that i need to take note off?
road tax will be $1.1+k , FC i read is 11~13km/L.
if you do come across an good condition w204, do drop me a ping as well
  • FCMB changed the title to 2nd hand C180 CGI W204 1.6L (Coe-ed car)
No 1, 2, 3 & 4 is the key failure and high cost to repair  ... most like happened after high mileage or above 10 years old W204.
5 till end, all is wear & tear  .... so is depending on your usage also, how you drive that 10 years old horse.
And W204 engine is very hot, so do expect rubbers/hoses break or air leak.
Test drive carefully and be more alert on all sound.
  1. Gearbox
    • Torque Convertor (Speed Lost/ Slip Gear)
    • Solenoid/Solenoid Plate (Slip Gear)
  2. Engine
    • Cam-Magnet (Oil Leak/Seal broken)
    • Timing Chain (High Mileage/Sound from Engine)
    • Seal/O-Rings/Sensor (Oil Leak)
  3. SuperCharger
    • Boot flat fail to operate (Lost of boost/engine check light)
  4. ECU
    • Strange fault that can't clear and reoccur.
    • Signal issue from sensor (Engine Check Light)
  5. ABS
    • No ABS 😜
    • ABS fault code (Engine check light)
  6. Steering lock/ignition control.
    • Cant switch on engine
  7. Front/Rear Bars
  8. Front/Rear Wheel Bearings
  9. Suspesion.
Bought a used C&C C180 Bluefficiency (YOM 2012) after 2.5 yr use from 1st owner in 2015 (20k mileage when bought) and drove it until March 2022 (9th year ~100k mileage).  Car regularly maintained and in very good condition.  I was contemplating renewing COE but in the end traded in to C&C for another new model as I was given a very attractive trade-in offer.
Had no major issues (did not encounter key or green key issue) other than the usual maintenance servicing & wear&tear replacement.
Regular Maintenance (annually) can be carried out at C&C or many other outside MB specialist workshops at reasonable price.
