WTS: Mercedes SL280 R129
kazeasura
Cheapest Depre in the market and done up.
etting go my R129 ! Body may not be a W124 but chassis is!
https://m.sgcarmart.com/used_cars/info.php?ID=1130784
Cheapest Sl280 in the market with lots of items done up
R Springs
Undercarriage fully done up
New Shock Absorbers , Mounts , Lower Arms , tierods, bushings etc
H&R Lowered Springs
Wheel bearings, Steering stablizer
New front suspension components for tightness
Comes with hardtop
Engine is smooth running.
Plugs, Ignition Coil All changed, spark plug cover
new o2 sensors, MAF sensors, crankshaft sensor, camshaft sensor basically all sensors new, knock sensors
New valve cover gasket, Valve cover
Engine oil pressure switch, transmission pressure switch
Icy Cold aircon- New aircon compressor
Injectors, Fuel regulator,
Timing Chain, Timing chain guide
Soft top working condition - No leaks from hydraulic fluid. Has been rebuilt before. ready to last another 10-20 years
No engine oil leak,coolant leak
Comes with nice 4 digit number
wa 88215616 for more enquiries
