SQUEAKING SOUND FROM DOOR PANEL
purple_cat
Hi, my W205 every time run over uneven surface or hump, the front passenger door panel produce irritating squeaking sound ,have tried WD40 and 3M silicon spray to lubricate gaps and moving parts but still unable to eliminate it , any member here have similar issue before and have rectified it, kindly share how or where you get it resolved- TIA
  • Replies 4
Then your only option is to get your hands on some Krytox or Gummi Pfledge.  Krytox is the favorite among VW owners in Singapore too.  Just to give you an idea of what needs to be done, check out this link from the BMW folks:
https://www.m3post.com/forums/showthread.php?t=1017134
Gummi Pfleger
Gummi Pfleger
Hi , thanks for the link , will explore it
