Dekit sales - W177 ST XA coilover for sale with WARRANTY.
GEE
PRICE REDUCED FROM $1200 (UP $2247SGD - With Receipt) Previously on Mercedes A200 W177 2019.
Check your car model compatibility here
https://www.st-suspensions.net/shop?c_make=74&c_model=36676&c_car=120283
Warranty from ST Suspension till 2026, Unlimited Mileage
https://www.stsuspensions.com/warranty_returns?gclid=Cj0KCQjwwJuVBhCAARIsAOPwGATzvE59lupqDMrv__lcj81HxE1_bg8zaq4t697Hfg4YZbJENMWKALgaAnZ4EALw_wcB
) ST XA MORE THAN JUST LOWERING With the adjustable dampers, you can influence more than just the ride height of your car. Whether your style is comfort or performance, with the ST XA Coilover you are in control of your driving dynamics. ST XA: PERFECTLY ADAPT TO THE ROAD AHEAD OF YOU For all those who want to influence more than just their ride height. ST XA Coilovers deliver the look you need through a wide range of height adjustment. With an extensively adjustable damper setup, you can precisely adjust the driving behavior of your car to achieve enhanced road control without a compromise in comfort. ST XA Coilover kits deliver precise adjustment to your ride height and look of your car. We manufacture the adjustable spring perch made of durable and friction-optimized polyamide composite material with a stainless steel insert. Thanks to the composite material corrosion is prevented between the strut and perch ensuring long lasting height adjustability while the stainless steel insert provides strength and confidence! ST XA Coilovers come preset to our factory recommended damper settings, the same configuration we test them at on our KW shock dynos before they go into your box. The 16 distinct clicks of adjustable rebound damping allow you to refine the driving dynamics with a simple turn of the adjustment knob. Each kit includes a detailed damper setup manual making it easy to reset to our recommended setting at any time. Whether your preference is comfort, sportiness, or something in between; ST XA puts the finer details of the driving dynamics in your hands. #A160 #A160D #A180 #180D #A200 #A200D #A220 #A220D #A250 #w177 #mercedes #coilover #suspension #carmods
  • 4 months later...
