W204 change headlight bulb to LED
BoHoSeh
On 12/2/2020 at 5:59 PM, snsd555 said:
I think Autobacs sells headlight replacement bulbs in the LED form
Just make sure they are the right size and wattage, the technicians there should be able to assist you.
As for DRL, i'm not too sure, you might want to contact lighting expert @EleBest.
Thanks for the reply. Will check with them.
