How to remove those Tag that stick on boot
Guest Clear Vision
Guest Clear Vision
Hi Guys,
Any idea how to remove those tag "C200 and Kompressor" that stick on the rear of the boot without scratching the paint work? Use dental floss? Any brother did before?
Thanks
  • Replies 6
Guest daywalker
Hi Guys,
Thanks
yes, i use dental floss to do it and it turns out fine.
Just place the floss behind the badge and "cut" through the adhesive by running it down in a left-right motion and in no time, you will reach the bottom. you can use your fingers to remove the leftovers on the care before cleaning the suface with wipes.
Guest ehwwong
becareful though, i kanak some light scratches when removed the C&C badge... not sure whether the scratch was there and the C&C badge was used to cover it... :banghead:
the rest are OK.. prepare some good polish to remove residue glue
